[Qgis-developer] Building plugin for Print Composer
Vincent Mora vincent.mora at oslandia.com
Fri Aug 14 06:41:02 PDT 2015
Le 08/08/2015 11:19, Nyall Dawson a écrit :
> On 7 Aug 2015 6:58 pm, "Vincent Mora" <vincent.mora at oslandia.com
> <mailto:vincent.mora at oslandia.com>> wrote:
> > Hi all,
> > I need to add graphs generated by a plugin to compositions. I'm
> considering to develop a PluginComposerItem in the same spirit as
> PluginLayers, adding/removing a button in the toolbar when the plugin
> is registered/removed.
Hi Nyall,
> Just a warning that similar work is already underway - adding a
> composer item type registry so that plugins can register their own
> custom item types.
Thanks for the warning.
Are you referring to QEP#9 or to something else ?
What is the status of the work that is "underway" ?
What is the planned time-frame ?
Is there a branch somewhere that I can base my work on / contribute to ?
We need a composer plugin item for a customer project with a deadline in
November. We have planned a few days of dev to contribute that and we'd
rather put those efforts in a long term solution.
> It's an extensive work though, because composer has a lot of hard
> coded handling of all the existing item types (checkout all the item
> specific methods in QgsComposition/QgsComposerView). That's why this
> work is tied up with the layouts/reporting framework refactor.
I've seen that, and I'm not sure I see why it prevents the introduction
of a plugin item (+registry) that would be used as a base class for
python objects to draw in a frame that is part of a composition.
V.
> Nyall
> > Is that what was needed in your cases, or was a more general
> approach required (like the qgis plugin mechanism, being able to
> access the interface) ?
> > V.
> > Le 22/06/2015 18:05, G. Allegri a écrit :
> >> The suggestion from John is exactly what we did too. And we also
> built a chart composer...
> >> It would be great to have the means to know what other teams are
> working to. It would save a lor of time and money and, probably, get
> better software from a shared effort ;)
> >> giovanni
> >> Il 22/giu/2015 19:31, "John Gitau" <gkahiu at gmail.com
> <mailto:gkahiu at gmail.com>> ha scritto:
> >>> Hi Jakob,
> >>> A workaround would be to have a plugin that creates a new composer
> view object:
> >>> custom_composer = self.iface.createNewComposer("My Composer")
> >>> Then get a reference to the main window in the composer view:
> >>> main_window = custom_composer.composerWindow()
> >>> Then you can either add a new toolbar (and required actions) or
> append an action to the main toolbar. Have a look at the
> ComposerWrapper class for something similar we implemented for
> designing charts in the
> composer: https://gist.github.com/gkahiu/06a43a589f9441736397
> >>> Hope this is helpful.
> >>> Cheers,
> >>> John
> >>> On Mon, Jun 22, 2015 at 2:07 PM, G. Allegri <giohappy at gmail.com
> <mailto:giohappy at gmail.com>> wrote:
> >>>> You can act on it but you can't custom gui widgets to the
> Composer interface.
> >>>> I cannot check the code right know. I listen to a specific
> (existing) composition opening but if I remember correctly you can
> watch the Composer opening too.
> >>>> Il 22/giu/2015 17:19, "Jakob Lanstorp" <jlanstorp at gmail.com
> <mailto:jlanstorp at gmail.com>> ha scritto:
> >>>>> Hi Giovanni, thanks for the update. Another solution would be to
> catch the
> >>>>> event when a user starts an existing print composer. Cannot in
> doc for the
> >>>>> pyqgis API find anything for this. Anyone who know is one can
> listens for a
> >>>>> print composer to startup by the user and act on it.
> >>>>> Jakob Lanstorp
> >>>>> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Building-plugin-for-Print-Composer-tp5212187p5212221.html
> >>>>> Sent from the Quantum GIS - Developer mailing list archive at
> Nabble.com.
> >>>>> _______________________________________________
> >>>>> Qgis-developer mailing list
> >>>>> Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> >>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150814/435a5bde/attachment.html>
