[Qgis-developer] [Qgis-user] Any working GRASS in QGIS available? - Processing Bug?
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Tue Aug 11 12:29:23 PDT 2015
Hi Andrew
Am 06.08.2015, 19:20 Uhr, schrieb Andrew <amcaninch at gmail.com>:
> Victor,
> I edited the version of the processing plugin that i have installed
> (QGIS 2.8.3, processing 2.10.1) with the changes you made and >now
> GRASS7 tools work as they should, thanks!
> Andrew
Could you maybe describe a little bit what you have changed and how ?
Bernd
> On Thu, Aug 6, 2015 at 5:59 AM, Victor Olaya <volayaf at gmail.com> wrote:
>> A quick (but very relevant) note about GRASS7:
>> It seems that, in one of the latest changes, I unintentionally left
>> out a code line where GRASS was actually being called. I was getting a
>> bit crazy wondering where the error might be and why GRASS7 was not
>> working in the latest release....and finally found out that the reason
>> was that. So, in short, Processing was not running grass when running
>> a grass7 algorithm.
>> I have added that line back and it should be fine now.
>> If you can install the current master version, please test and let me
>> know if there are any issues or it is working correctly as before.
>> Regards
>> 2015-08-03 1:37 GMT+02:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
>>> Hi Alex
>>> Am 03.08.2015, 01:20 Uhr, schrieb Alex Mandel
>>> <tech_dev at wildintellect.com>:
>>>> Ah but we're closer to finding a solution with all those details. It
>>>> may
>>>> be fixable in Processing, which can be pushed to the plugin repo for
>>>> update any time.
>>>> Passing this along to devs who might have enough information now.
>>>> Thanks,
>>>> Alex
>>> Thanks for taking care,
>>> by the way: by copying the gdal algorithms from processing 2.10.1 to
>>> the
>>> 2.9.3 folder (.qgis2/python/plugins/processing/algs/gdal), I gained
>>> access
>>> to the new GDAL dissolve polygons :)
>>> Unfortunately, the model from before (GRASS6) didn't work anymore, and
>>> all
>>> attempts to adjust it via diff of a test model failed. So reworking my
>>> model
>>> (for the 10th time or so) in Ubuntu 2.8.3 from ubuntugis-ltr with
>>> working
>>> GRASS7, SAGA and everything and a partially upgraded Processing 2.9.3
>>> I'm on my way ... finally .. hopefully ...
>>> Bernd
>>>> On 08/02/2015 03:07 PM, Bernd Vogelgesang wrote:
>>>>> Am 02.08.2015, 22:44 Uhr, schrieb Alex Mandel
>>>>>> After some brief testing, my OSGeoLive 8.5 VM with QGIS 2.6 and
>>>>>> Processing 2.9.3, GRASS 7 works.
>>>>>> My QGIS 2.8, GRASS 6/7, Processing 2.10.1 does not.
>>>>> Gave Windows another try: Removed everything, and installed the
>>>>> simple
>>>>> install OSGEO4W setup.
>>>>> QGIS 2.10.1 with Processing 2.10.1 and GRASS 6 working.
>>>>> switched back to Ubuntu, cause of a bug in the modeler version of
>>>>> GDAL
>>>>> Dissolve Polygons (which is crucial for me).
>>>>> https://hub.qgis.org/issues/13174
>>>>> Ubuntu: Now that I installed 2.8 with the debian repository only (so
>>>>> without ubuntis depencies), my GRASS 6 works (sorted out another
>>>>> error,
>>>>> that GRASS takes a column name "OR" from shape as an sql-command or
>>>>> sth), update to Processing 2.10.1 worked as well.
>>>>> The drawback, no SAGA, which might come handy cause the now available
>>>>> algos do not really do what I expect ;)
>>>>> I think the problem is within Processing in combination with the
>>>>> packaging:
>>>>> When e.g. I install QGIS 2.8 with ubuntugis-ltr dependencies (where
>>>>> nobody on the install page claims I shouldn't do), GRASS7 and the
>>>>> modeler are working, but Processing version is 2.6. Updating
>>>>> Processing
>>>>> to current Processing 2.10.1 (as recommended) seems to work.
>>>>> (Besides that v.clean in the modeler only returns a polygon layer
>>>>> from
>>>>> an polygon input, if I also set an output name for the error layer,
>>>>> otherwise I get an empty line shape)
>>>>> But: The next time I run QGIS and want to run an GRASS algo: Missing
>>>>> depencies
>>>>> I can now replace Processing 2.10.1 with the second latest 2.9.3 from
>>>>> https://plugins.qgis.org/plugins/processing/version/2.9.3/
>>>>> and there v.clean does what it should in Processing AND modeler.
>>>>> But: Now I do not have GDAL Dissolve polygons which is in Processing
>>>>> 2.10.1. Well, I could switch back to Windows QGIS 2.10, but, grr,
>>>>> there
>>>>> is the bug in this algo ...
>>>>> You see, I'm trapped.
>>>>> Thanx for you attention
>>>>> Bernd
>>>>>> Both are Ubuntu 14.04 based.
>>>>>> I'm not sure if this is a bug in Processing, or in packaging. I
>>>>>> recall
>>>>>> in OSGeoLive 8.5 that we had custom packages with a patch. Note,
>>>>>> you can
>>>>>> get those versions for your Ubuntu system from
>>>>>> https://launchpad.net/~osgeolive/+archive/ubuntu/release-8.5
>>>>>> We freeze a copy of the working versions in our own ppa for long
>>>>>> term
>>>>>> history.
>>>>>> Thanks,
>>>>>> Alex
>>>>>> On 2015-08-02 03:32, Bernd Vogelgesang wrote:
>>>>>>> Hi Alex,
>>>>>>> Am 02.08.2015, 01:22 Uhr, schrieb Alex Mandel
>>>>>>>> It's not a Windows/Ubuntu/Mac/OS thing, it's a QGIS + GRASS
>>>>>>>> version
>>>>>>>> change thing.
>>>>>>>> Please indicate which version of QGIS and GRASS you are trying to
>>>>>>>> get
>>>>>>>> working.
>>>>>>> Actually I do not mind any more what version I would like to get
>>>>>>> working. I would have preferred the 2.8-LTR branch with
>>>>>>> no-matter-what
>>>>>>> GRASS version.
>>>>>>> I just would like to be able to finish my project, and there is
>>>>>>> unfortunately no alternative to the GRASS algos in my model.
>>>>>>>> QGIS 2.6 and older works with GRASS 6, 2.8+ sometimes is built to
>>>>>>>> work
>>>>>>>> with GRASS 7 (though possibly also with GRASS 6).
>>>>>>> Mhm, reverting to 2.6 ... Lets see if this still possible at all
>>>>>>>> If you want a guaranteed working setup ASAP download a copy of
>>>>>>>> OSGeo
>>>>>>>> Live Virtual Machine, we made sure that it works in that.
>>>>>>>> http://live.osgeo.org
>>>>>>> Will give it a try. Download will take another 1.5 hours ...
>>>>>>> So does that mean that even your do not have a working GRASS in a
>>>>>>> recent
>>>>>>> QGIS by "normal" means but the osgeo VM?
>>>>>>>> Thanks,
>>>>>>>> Alex
>>>>>>> Cheers
>>>>>>> Bernd
>>>>>>>> On 2015-08-01 14:41, Bernd Vogelgesang wrote:
>>>>>>>>> Hi guys,
>>>>>>>>> is it just bad karma, that I seem not to able to get a working
>>>>>>>>> GRASS in
>>>>>>>>> QGIS? Or did I miss the big advertisement "GRASS out of order"
>>>>>>>>> somewhere.
>>>>>>>>> For nearly 2 weeks, I tried to get things to work in
>>>>>>>>> Ubuntu/Mint, and
>>>>>>>>> tried every possible/impossible repository, but always GRASS has
>>>>>>>>> missing
>>>>>>>>> dependencies, the forms open in Processing, but the algos don't
>>>>>>>>> run
>>>>>>>>> through, or the functions are working in Processing, but failing
>>>>>>>>> in
>>>>>>>>> the
>>>>>>>>> modeller.
>>>>>>>>> As I really got to finish a model in the Modeller including some
>>>>>>>>> GRASS
>>>>>>>>> algos, I finally turned on my VM with Windows ...
>>>>>>>>> but what the heck? Same s...t there!
>>>>>>>>> I really wonder why there aren't many post about trouble with
>>>>>>>>> GRASS
>>>>>>>>> on
>>>>>>>>> this list or at stackexchange, normally this would explode when
>>>>>>>>> things
>>>>>>>>> like these happen.
>>>>>>>>> So am I really the one with the bad karma, do you all other
>>>>>>>>> simply
>>>>>>>>> not
>>>>>>>>> use GRASS in processing as much as I do, or do you all simply
>>>>>>>>> have
>>>>>>>>> working installs, so there is not problem?
>>>>>>>>> Please, at least one: Do you have an install under Ubuntu or
>>>>>>>>> Windows,
>>>>>>>>> where GRASS algos are functional in the Modeler ? If yes, which
>>>>>>>>> version/what did you do?
>>>>>>>>> ... Soon, I will go and find me a rope ...
>>>>>>>>> Bernd
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Bernd Vogelgesang
>>> Siedlerstraße 2
>>> 91083 Baiersdorf/Igelsdorf
>>> Tel: 09133-825374
Bernd Vogelgesang
Siedlerstraße 2
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150811/3e705e93/attachment.html>
