[Qgis-developer] QGIS indexing data when editing
Vincent Picavet (ml)
vincent.ml at oslandia.com
Thu Aug 13 03:12:55 PDT 2015
Hello,
30s freeze is something which seems rather unpleasant for the user.
Could we imagine to do the indexing in background ?
And maybe indexing only what is currently in the user's extent, if this
is not what is currently done ?
Indexing a whole layer for editing seems a no-go. We should maybe have a
way to get the user to use the indexing tools only when zoomed in ?
Vincent
On 13/08/2015 07:38, Denis Rouzaud wrote:
> Dear Nicolas,
> The indexing is used for snapping in the application.
> It takes a few sec when enable the first tool, but snapping is much
> faster later on.
> Best wishes,
> Denis
> On 08/12/2015 02:30 PM, Doctor Who wrote:
>> Hello,
>> I'm using QGIS 2.10.1 and 2.8.3 with PostGreSQL 9.3 and PostGIS 2.5 under
>> Linux openSUSE 13.2 64bits.
>> A strange things appear since i've move from PostGreSQL 9.1 -> 9.3
>> Each time I open a layer for editing, when I selected any tools (node
>> tools
>> or creation entity tools), QGIS freeze about 30 sec and display 'indexing
>> data' progress bar. (memory of my computer grow up in same time)
>> After that, I could editing my data, close it and reopen editing session
>> whithout any problem or any crash.
>> But if I close my project and reopen it, again indexing data when I
>> want to
>> edit a layer.
>> I've seen that new thing under a small layer (90 entities) and bigger one
>> (about 250 000 objects), same things for Polygon or Point geometry.
>> I've a primary key constraint and a spatial index.
>> Have you already see that somewhere else ? I can't find why as it never
>> happens before.
>> Best regards,
>> Nicolas
>> GIS administrator in Urban Agency of the Greater Amiens
>> Founder and main administrator of forumSIG
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-indexing-data-when-editing-tp5219525.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
