[Qgis-developer] QGIS indexing data when editing
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Aug 13 05:17:56 PDT 2015
On 08/13/2015 12:12 PM, Vincent Picavet (ml) wrote:
> Hello,
> 30s freeze is something which seems rather unpleasant for the user.
I am not experiencing such freeze. With a project with ~100 layers, with
10 having more than 10k features, I have something around 2 to 3 seconds.
I beleive this is reasonable.
> Could we imagine to do the indexing in background ?
Indexing is started when an editing map tools (or I believe any snapping
operation) is enabled.
Since it is required on mouse events, it needs to freeze the app in the
mean time.
> And maybe indexing only what is currently in the user's extent, if this
> is not what is currently done ?
Would be an idea, although I am not sure this is really required. Nobody
complained very much yet about this.
Martin would have to answer for saying if it's feasible or not.
> Indexing a whole layer for editing seems a no-go. We should maybe have a
> way to get the user to use the indexing tools only when zoomed in ?
> Vincent
> On 13/08/2015 07:38, Denis Rouzaud wrote:
>> Dear Nicolas,
>> The indexing is used for snapping in the application.
>> It takes a few sec when enable the first tool, but snapping is much
>> faster later on.
>> Best wishes,
>> Denis
>> On 08/12/2015 02:30 PM, Doctor Who wrote:
>>> Hello,
>>> I'm using QGIS 2.10.1 and 2.8.3 with PostGreSQL 9.3 and PostGIS 2.5 under
>>> Linux openSUSE 13.2 64bits.
>>> A strange things appear since i've move from PostGreSQL 9.1 -> 9.3
>>> Each time I open a layer for editing, when I selected any tools (node
>>> tools
>>> or creation entity tools), QGIS freeze about 30 sec and display 'indexing
>>> data' progress bar. (memory of my computer grow up in same time)
>>> After that, I could editing my data, close it and reopen editing session
>>> whithout any problem or any crash.
>>> But if I close my project and reopen it, again indexing data when I
>>> want to
>>> edit a layer.
>>> I've seen that new thing under a small layer (90 entities) and bigger one
>>> (about 250 000 objects), same things for Polygon or Point geometry.
>>> I've a primary key constraint and a spatial index.
>>> Have you already see that somewhere else ? I can't find why as it never
>>> happens before.
>>> Best regards,
>>> Nicolas
>>> GIS administrator in Urban Agency of the Greater Amiens
>>> Founder and main administrator of forumSIG
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-indexing-data-when-editing-tp5219525.html
>>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
