[Qgis-developer] QGIS indexing data when editing
Denis Rouzaud denis.rouzaud at gmail.com
Thu Aug 13 07:40:19 PDT 2015
On 08/13/2015 04:37 PM, Jean-Roc Morreale wrote:
> Le 2015-08-13 16:31, Denis Rouzaud a écrit :
>> On 08/13/2015 04:28 PM, Jean-Roc Morreale wrote:
>>> Le 2015-08-13 16:04, Denis Rouzaud a écrit :
>>>> on my project, a progress appears, but there's a threshold around
>>>> about 2 seconds (i.e. appears only when it takes a certain time).
>>>> which version of QGIS are you using?
>>>> the progress bar was added a bit later than the snapping refactoring.
>>> 2.8.1 (I can't try 2.10, the next possible update will be in january
>>> 2016)
>> should be in 2.8
>> https://github.com/qgis/QGIS/commit/e22edc82ef9b27875f78bf28de0d50ffa83eb5e7
> I made a new try but couldn't see any progress bar, the only thing is
> the cursor in "load" mode and a message at the end in the bottom left
> corner saying that the validation is over.
Is this one big layer or several?
 From what I read, you'll see the progress over several layers but not
within a single layer.
