[Qgis-developer] QGIS indexing data when editing
Jean-Roc Morreale jr.morreale at enoreth.net
Thu Aug 13 07:49:58 PDT 2015
Le 2015-08-13 16:40, Denis Rouzaud a écrit :
> On 08/13/2015 04:37 PM, Jean-Roc Morreale wrote:
>> Le 2015-08-13 16:31, Denis Rouzaud a écrit :
>>> On 08/13/2015 04:28 PM, Jean-Roc Morreale wrote:
>>>> Le 2015-08-13 16:04, Denis Rouzaud a écrit :
>>>>> on my project, a progress appears, but there's a threshold around
>>>>> about 2 seconds (i.e. appears only when it takes a certain time).
>>>>> which version of QGIS are you using?
>>>>> the progress bar was added a bit later than the snapping
>>>>> refactoring.
>>>> 2.8.1 (I can't try 2.10, the next possible update will be in january
>>>> 2016)
>>> should be in 2.8
>>> https://github.com/qgis/QGIS/commit/e22edc82ef9b27875f78bf28de0d50ffa83eb5e7
>> I made a new try but couldn't see any progress bar, the only thing is
>> the cursor in "load" mode and a message at the end in the bottom left
>> corner saying that the validation is over.
> Is this one big layer or several?
> From what I read, you'll see the progress over several layers but not
> within a single layer.
At first with one but I made a new try with 4 four layers, all in
editing mode with snapping activated and use the node selector on one
