[Qgis-developer] QGIS indexing data when editing
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Aug 13 08:03:13 PDT 2015
On 08/13/2015 04:49 PM, Jean-Roc Morreale wrote:
> Le 2015-08-13 16:40, Denis Rouzaud a écrit :
>> On 08/13/2015 04:37 PM, Jean-Roc Morreale wrote:
>>> Le 2015-08-13 16:31, Denis Rouzaud a écrit :
>>>> On 08/13/2015 04:28 PM, Jean-Roc Morreale wrote:
>>>>> Le 2015-08-13 16:04, Denis Rouzaud a écrit :
>>>>>> on my project, a progress appears, but there's a threshold around
>>>>>> about 2 seconds (i.e. appears only when it takes a certain time).
>>>>>> which version of QGIS are you using?
>>>>>> the progress bar was added a bit later than the snapping
>>>>>> refactoring.
>>>>> 2.8.1 (I can't try 2.10, the next possible update will be in
>>>>> january 2016)
>>>> should be in 2.8
>>>> https://github.com/qgis/QGIS/commit/e22edc82ef9b27875f78bf28de0d50ffa83eb5e7
>>> I made a new try but couldn't see any progress bar, the only thing
>>> is the cursor in "load" mode and a message at the end in the bottom
>>> left corner saying that the validation is over.
>> Is this one big layer or several?
>> From what I read, you'll see the progress over several layers but not
>> within a single layer.
> At first with one but I made a new try with 4 four layers, all in
> editing mode with snapping activated and use the node selector on one
I can't tell.
Let's wait for Martin's feedback...
