[Qgis-developer] WktExport plugin for QGIS
Geo DrinX
geodrinx at gmail.com
Wed Aug 26 00:30:42 PDT 2015
I'm glad that my small and futile plugin may have been useful to improve
the interface of QGIS, and reveal powerful hidden possibilities.
"The useless can sometimes be useful"
I will write an useless book about this ;)
Thank you and regards
Roberto
2015-08-26 9:20 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> Hi,
> As Even already said that with gdal 2.0 it is possible to populate an
> options list automatically.
> I think it should be possible that, depending on the GDAL version, we
> already integrate this into the "Save As" Dialog for people already
> using gdal 2.0 .. and for all others maybe "help popups" could
> describe where to find info about the options that are possible to
> use. (ok - that should have been done long time ago :) )
> For GDAL < 2.0 the text box was on purpose, so that users can enter
> whatever they find on the GDAL webpages and use it.
> regards,
> Werner
> On Wed, Aug 26, 2015 at 9:12 AM, Anita Graser <anitagraser at gmx.at> wrote:
> > On Wed, Aug 26, 2015 at 8:24 AM, Geodrinx <geodrinx at gmail.com> wrote:
> >> Hi Paolo,
> >> > I'm trying to reduce redundancy in the plugin repo: would you think it
> >> > is really useful to publish this one, given that it replicates
> exixting
> >> > functionality?
> >> > Thanks for your opinions.
> >> I will integrate my code into another plugin, to support 3D point
> saving.
> >> So, I admit, WktExport is not so important (also if it could be didactic
> > I'd rather if we could keep it unpublished if Roberto doesn't mind. Save
> as
> > CSV code is already maintained in core. If newbies see the plugin in the
> > list, they might assume that it's the only way and in case it breaks they
> > could think that QGIS has no more capabilities to export CSV.
> > Best wishes,
> > Anita
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150826/ae316f25/attachment.html>
