[Qgis-developer] WktExport plugin for QGIS
Werner Macho werner.macho at gmail.com
Wed Aug 26 00:20:09 PDT 2015
As Even already said that with gdal 2.0 it is possible to populate an
options list automatically.
 I think it should be possible that, depending on the GDAL version, we
already integrate this into the "Save As" Dialog for people already
using gdal 2.0 .. and for all others maybe "help popups" could
describe where to find info about the options that are possible to
use. (ok - that should have been done long time ago :) )
For GDAL < 2.0 the text box was on purpose, so that users can enter
whatever they find on the GDAL webpages and use it.
regards,
Werner
On Wed, Aug 26, 2015 at 9:12 AM, Anita Graser <anitagraser at gmx.at> wrote:
> On Wed, Aug 26, 2015 at 8:24 AM, Geodrinx <geodrinx at gmail.com> wrote:
>> Hi Paolo,
>> > I'm trying to reduce redundancy in the plugin repo: would you think it
>> > is really useful to publish this one, given that it replicates exixting
>> > functionality?
>> > Thanks for your opinions.
>> I will integrate my code into another plugin, to support 3D point saving.
>> So, I admit, WktExport is not so important (also if it could be didactic
> I'd rather if we could keep it unpublished if Roberto doesn't mind. Save as
> CSV code is already maintained in core. If newbies see the plugin in the
> list, they might assume that it's the only way and in case it breaks they
> could think that QGIS has no more capabilities to export CSV.
> Best wishes,
> Anita
> Qgis-developer mailing list
