[Qgis-developer] digitizing issues in master
Régis Haubourg
regis.haubourg at eau-adour-garonne.fr
Thu Aug 27 07:11:56 PDT 2015
I'm digitizing in current master and couldn't achieve my work, had to switch
back to 2.10.
First issue is not being able to select a bunch of node with node tool using
clic and drag on screen. Did that change?
Second issue is new node window coming up automatically . The interaction
with canvas is unclear to me, just mousing over it and that snapped some
node in the list and started moving those node somewhere outside of my
digitising extent. The node window is a good idea. That should really show
only node in screen extent IMHO. Selecting a node from the list should be
more explicit, and one should be able to deactivate that I think.
Third issue is that I couldn't find a way to release the "snapped node". Had
to finish move the node and the undo the edit.
Is there some work in progress there?
Cheers
Régis
View this message in context: http://osgeo-org.1560.x6.nabble.com/digitizing-issues-in-master-tp5221470.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
