[Qgis-developer] digitizing issues in master
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Aug 27 07:39:29 PDT 2015
Marco is working on the node tool.
It has been reworked to allow Z/M editing.
It is now in click-click mode (not drag and drop anymore) to allow
keybord input while moving a node for advanced digitizing.
There are a bunch of issues I opened:
http://hub.qgis.org/issues/13257
http://hub.qgis.org/issues/13275
http://hub.qgis.org/issues/13276
A polished node tool should come soon, as it is barely usable in its
current state.
Denis
On 08/27/2015 04:11 PM, Régis Haubourg wrote:
> Hi,
> I'm digitizing in current master and couldn't achieve my work, had to switch
> back to 2.10.
> First issue is not being able to select a bunch of node with node tool using
> clic and drag on screen. Did that change?
> Second issue is new node window coming up automatically . The interaction
> with canvas is unclear to me, just mousing over it and that snapped some
> node in the list and started moving those node somewhere outside of my
> digitising extent. The node window is a good idea. That should really show
> only node in screen extent IMHO. Selecting a node from the list should be
> more explicit, and one should be able to deactivate that I think.
> Third issue is that I couldn't find a way to release the "snapped node". Had
> to finish move the node and the undo the edit.
> Is there some work in progress there?
> Cheers
> Régis
> View this message in context: http://osgeo-org.1560.x6.nabble.com/digitizing-issues-in-master-tp5221470.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
