[Qgis-developer] What is Processing Provider Plugin Builder option?
m roy
royroge at outlook.com
Wed Dec 2 00:35:12 PST 2015
Il 02/12/2015 09:19, Etienne Trimaille ha scritto:
You can add your own plugin into the processing framework. It will add a new entry in the "Advanced interface" of Processing.
Unfortunately, I couldn't find any documentation, but you can have a look to this example :
https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/exampleprovider
- ProcessingExampleProviderPlugin will add the plugin to Processing
- ExampleAlgorithmProvider will list every algorithms available in the plugin
- ExampleAlgorithm is an algorithm
Some plugins provides their own algorithms in Processing (QuickOSM ...)
Very useful thanks !
in the meantime i managed to activate a "blank" provider plugin
after restarting QGIS and activating the new provider in the processing options menu
it does not show up in the simplified interface indeed, maybe because i did not use an already
existing processing menu (raster, vector etc...)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151202/d798d24d/attachment-0001.html>
