[Qgis-developer] selective features unselection
Andreas Neumann a.neumann at carto.net
Wed Dec 2 02:29:10 PST 2015
Hi Strk,
It is indeed a bit problematic, esp. since other applications (Inkscape,
LibreOffice) use the Shift key to do the same thing. It would be great
if QGIS could align with that behavior that people already know from
other software.
But maybe there is a technical reason to use the Ctrl-Key instead of the
Shift-Key.
Andreas
On 02.12.2015 11:24, Sandro Santilli wrote:
> I tried something and.. found !
> Keeping CTRL pressed toggles inclusion of selected
> features in the "selected" set.
> Then I guess it's just an UX issue that needs be fixed.
> How should UX feature requests be reported ?
> --strk;
> On Wed, Dec 02, 2015 at 11:20:53AM +0100, Sandro Santilli wrote:
>> I had not found a way to selectively remove features from
>> the selection set via the GUI, does any such functionality exist ?
>> The "unselect features" tool drastically unselect _all_ features.
>> Ideally I'd like to be able to perform set-oriented operations
>> on the selection, adding or removing elements with the same selection
>> power (by rectangle, polygon, freehand or programmatically).
>> Is this available already or planned for any future release ?
>> --strk;
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
