[Qgis-developer] Problem in Displaying Myanmar Unicode Font in QGIS
Mathieu Pellerin
nirvn.asia at gmail.com
Thu Dec 10 02:59:02 PST 2015
I should have read your email more carefully, you quite clearly state that
the rendering is broken on windows too. Good to know, as it offers yet one
more argument to support the migration to Qt5.
Just in case this might actually be a font problem instead of a rendering
problem, have you tried to display the ZawGyiOne and unicode text using the
appropriate font (vs. the default system font which is used in the
attribute table shown in your screenshots)?
Instructions to build QGIS are here:
https://github.com/qgis/QGIS/blob/master/INSTALL, however it doesn't cover
Qt5. Maybe Matthias Kuhn can help here.
Math
On Thu, Dec 10, 2015 at 5:33 PM, KhunSanAung <khunsanaung.gis at gmail.com>
wrote:
> Great to hear Math.
> Where can I download QGIS source code for 32 bit & 64 bit Windows and if
> will make us easy if some reference document for building are also
> available?
> I'm happy to try it.
> Many thanks & best regards
> On Thu, Dec 10, 2015 at 2:56 PM, Mathieu Pellerin <nirvn.asia at gmail.com>
> wrote:
>> I should have added that Qt4 doesn't have rendering issues because it
>> shapes text using the windows uniscribe library.
>> On 10 Dec 2015 15:25, "Mathieu Pellerin" <nirvn.asia at gmail.com> wrote:
>>> Greetings,
>>> Long story short, QGIS compiled against Qt4 (which is what the official
>>> version does) doesn't support proper Burmese script ordering under linux.
>>> This is due to Qt4 (not actively developed anymore) using an old library to
>>> shape unicode scripts.
>>> QGIS compiled against Qt5 fixes all rendering issues for Burmese
>>> language.
>>> Therefore at the moment your options are to either
>>> a/ run QGIS on windows 7 (within a virtual machine if you don't want to
>>> permanently install the OS); or
>>> b/ compile a QGIS build for yourself if you are able to do so, from
>>> which you could create packages to distribute to other users.
>>> Math
> Have a nice day!
> *Mr. Khun San Aung*
> * <http://geoportal.icimod.org/>*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151210/8ca3d170/attachment.html>
