[Qgis-developer] Problem in Displaying Myanmar Unicode Font in QGIS
KhunSanAung
khunsanaung.gis at gmail.com
Thu Dec 10 18:44:40 PST 2015
Hi Math,
Sure, I've used the appropriate fonts for each of them.
They both have issue.
I'll try building from source code.
On Thu, Dec 10, 2015 at 5:29 PM, Mathieu Pellerin <nirvn.asia at gmail.com>
wrote:
> I should have read your email more carefully, you quite clearly state that
> the rendering is broken on windows too. Good to know, as it offers yet one
> more argument to support the migration to Qt5.
> Just in case this might actually be a font problem instead of a rendering
> problem, have you tried to display the ZawGyiOne and unicode text using the
> appropriate font (vs. the default system font which is used in the
> attribute table shown in your screenshots)?
> Instructions to build QGIS are here:
> https://github.com/qgis/QGIS/blob/master/INSTALL, however it doesn't
> cover Qt5. Maybe Matthias Kuhn can help here.
> Math
> On Thu, Dec 10, 2015 at 5:33 PM, KhunSanAung <khunsanaung.gis at gmail.com>
> wrote:
>> Great to hear Math.
>> Where can I download QGIS source code for 32 bit & 64 bit Windows and if
>> will make us easy if some reference document for building are also
>> available?
>> I'm happy to try it.
>> Many thanks & best regards
>> On Thu, Dec 10, 2015 at 2:56 PM, Mathieu Pellerin <nirvn.asia at gmail.com>
>> wrote:
>>> I should have added that Qt4 doesn't have rendering issues because it
>>> shapes text using the windows uniscribe library.
>>> On 10 Dec 2015 15:25, "Mathieu Pellerin" <nirvn.asia at gmail.com> wrote:
>>>> Greetings,
>>>> Long story short, QGIS compiled against Qt4 (which is what the official
>>>> version does) doesn't support proper Burmese script ordering under linux.
>>>> This is due to Qt4 (not actively developed anymore) using an old library to
>>>> shape unicode scripts.
>>>> QGIS compiled against Qt5 fixes all rendering issues for Burmese
>>>> language.
>>>> Therefore at the moment your options are to either
>>>> a/ run QGIS on windows 7 (within a virtual machine if you don't want to
>>>> permanently install the OS); or
>>>> b/ compile a QGIS build for yourself if you are able to do so, from
>>>> which you could create packages to distribute to other users.
>>>> Math
>> Have a nice day!
>> *Mr. Khun San Aung*
>> * <http://geoportal.icimod.org/>*
Have a nice day!
*Mr. Khun San Aung*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151211/f343efda/attachment.html>
