[Qgis-developer] Using pgservice.conf doesn't work to save styles in DB
Luigi Pirelli
luipir at gmail.com
Mon Dec 14 23:51:42 PST 2015
As far as I know/remember the get/creation of style use the same
connection, so, I found really strange this problem, and seems more a
server side configuration problem.
if you can replicate it, please feel free to file an issue
cheers
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 14 December 2015 at 08:52, Carlos López PSIG <carlos.lopez at psig.es>
wrote:
> Hi Luigi,
> Yes, always using the same schema and the same user...
> Is this a bug?
> thanks,
> * <http://www.psig.es>*
> *Carlos López Quintanilla*
> www.psig.es
> +34 699.680.261
> 2015-12-12 15:56 GMT+01:00 Luigi Pirelli <luipir at gmail.com>:
>> In the same schema? With same or allowed user permission on the created
>> style table?
>> Remeber that styla table container is on the fly created where the layer
>> rede => hinerith user ownership of the connection.
>> Cheers
>> On Friday, 11 December 2015, Carlos López PSIG <carlos.lopez at psig.es>
>> wrote:
>>> Hi,
>>> Today I saved styles for some layers from PostGIS, and few minutes
>>> before I change how to connect to PostGIS, now I using pgservice.conf
>>> following this link:
>>> http://qgep.github.io/docs/installation-guide/system/workstation.html
>>> (thanks to Barascu Tudor)
>>> I can save styles in database, but I can't use this styles after in
>>> another layer or in the same layer in another map...
>>> when I used a normal connection to PostGIS I could use this option!
>>> Is this a problem known?
>>> Should I do a comit in github?
>>> Thank in advance and best regards,
>>> www.psig.es
>>> +34 699.680.261
>> Luigi Pirelli
>> * Mastering QGIS:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151215/bf1d649c/attachment.html>
