[Qgis-developer] Using pgservice.conf doesn't work to save styles in DB
Carlos López PSIG
carlos.lopez at psig.es
Sun Dec 13 23:52:55 PST 2015
Hi Luigi,
Yes, always using the same schema and the same user...
Is this a bug?
thanks,
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2015-12-12 15:56 GMT+01:00 Luigi Pirelli <luipir at gmail.com>:
> In the same schema? With same or allowed user permission on the created
> style table?
> Remeber that styla table container is on the fly created where the layer
> rede => hinerith user ownership of the connection.
> Cheers
> On Friday, 11 December 2015, Carlos López PSIG <carlos.lopez at psig.es>
> wrote:
>> Hi,
>> Today I saved styles for some layers from PostGIS, and few minutes before
>> I change how to connect to PostGIS, now I using pgservice.conf following
>> this link:
>> http://qgep.github.io/docs/installation-guide/system/workstation.html
>> (thanks to Barascu Tudor)
>> I can save styles in database, but I can't use this styles after in
>> another layer or in the same layer in another map...
>> when I used a normal connection to PostGIS I could use this option!
>> Is this a problem known?
>> Should I do a comit in github?
>> Thank in advance and best regards,
>> www.psig.es
>> +34 699.680.261
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151214/6d2def96/attachment.html>
