[Qgis-developer] Using pgservice.conf doesn't work to save styles in DB
Carlos López PSIG carlos.lopez at psig.es
Thu Dec 10 15:08:59 PST 2015
Today I saved styles for some layers from PostGIS, and few minutes before I
change how to connect to PostGIS, now I using pgservice.conf following this
link:
http://qgep.github.io/docs/installation-guide/system/workstation.html
(thanks to Barascu Tudor)
I can save styles in database, but I can't use this styles after in another
layer or in the same layer in another map...
when I used a normal connection to PostGIS I could use this option!
Is this a problem known?
Should I do a comit in github?
Thank in advance and best regards,
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151211/c2791aa3/attachment.html>
