[Qgis-developer] New GRASS plugin: a test drive
Radim Blazek
radim.blazek at gmail.com
Tue Dec 15 03:29:14 PST 2015
On Thu, Oct 8, 2015 at 10:47 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Finally, I was wondering if it could be an idea to place all mapset related buttons (open / close / new / change mapset) at the bottom of the Modules dialogue and to add a "manage mapset access" button, which runs the mapset picker for modifying the search path (g.mapsets -s) there as well? One (I if you like) can add g.mapsets with the s-flag as a module (I tested "g.mapsets -s" in the QGIS-GRASS-plugin and it starts the GRASS dialogue successfully), but it is probably better to have this option a bit more prominent (as it might come in handy with the new multiple map input option)?
I have added "Add/Remove mapset to/from search path" as new browser
actions in master. There are now also distinct icons for mapset, open
mapset and mapset in search path.
Radim
