[Qgis-developer] Problems with installing QGIS on Linux Mint
James Stott
jamesstott1 at gmail.com
Tue Dec 15 11:24:39 PST 2015
I tried to upgrade QGIS on my system without success. I have also tried to
uninstalling and to reinstall but I cannot get it to work.
I have recently upgraded to Linux Mint 17.3 (dont know if thats relevant).
I get the following error when I try to install (apologies my system is in
Norwegian):
Setter opp qgis-providers-common
(1:2.12.1+git20151211+80c5cb6+20trusty-ubuntugis) ...
cp: cannot stat ‘/usr/share/qgis/resources/srs-template.db’: No such file
or directory
dpkg: error processing package qgis-providers-common (--configure):
underprosessen installerte post-installation-skript returnerte feilstatus 1
dpkg: dependency problems prevent configuration of qgis-providers:
qgis-providers krever qgis-providers-common (=
1:2.12.1+git20151211+80c5cb6+20trusty-ubuntugis). Men:
Pakke qgis-providers-common er ikke satt opp enda.
dpkg: error processing package qgis-providers (--configure):
kravproblem - setter ikke opp pakken
dpkg: dependency problems prevent configuration of qgis:
qgis krever qgis-providers (=
Pakke qgis-providers er ikke satt opp enda.
dpkg: error processing package qgis (--configure):
dpkg: dependency problems prevent configuration of qgis-plugin-grass:
qgis-plugin-grass krever qgis (=
Pakke qgis er ikke satt opp enda.
dpkg: error processing package qgis-plugin-grass (--configure):
kravproblem - setter ikke opp pakken (dependancy problem - cannotg
Det oppsto feil ved behandling av:
qgis-providers
qgis
qgis-plugin-grass
I can open QGIS, but I get two errors on startup and the python
console,plugin installer, database manager are not available:
An error occured during execution of following code:
import pyplugin_installer
traceback.print_exception() failed
and
pyplugin_installer.initPluginInstaller()
Can anyone help?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151215/7a3a79fc/attachment.html>
