[Qgis-developer] Problems with installing QGIS on Linux Mint
Randal Hale rjhale at northrivergeographic.com
Tue Dec 15 11:50:23 PST 2015
Try to uninstall QGIS and then add this as a repo:
deb http://qgis.org/debian wily main
Try to reinstall - I haven't installed Mint 17 so I might give that a
shot to see if it works (currently running Ubuntu 15.10.
Randy
On 12/15/2015 02:24 PM, James Stott wrote:
> I tried to upgrade QGIS on my system without success. I have also
> tried to uninstalling and to reinstall but I cannot get it to work.
> I have recently upgraded to Linux Mint 17.3 (dont know if thats relevant).
> I get the following error when I try to install (apologies my system
> is in Norwegian):
> Setter opp qgis-providers-common
> (1:2.12.1+git20151211+80c5cb6+20trusty-ubuntugis) ...
> cp: cannot stat ‘/usr/share/qgis/resources/srs-template.db’: No such
> file or directory
> dpkg: error processing package qgis-providers-common (--configure):
>  underprosessen installerte post-installation-skript returnerte
> feilstatus 1
> dpkg: dependency problems prevent configuration of qgis-providers:
>  qgis-providers krever qgis-providers-common (=
> 1:2.12.1+git20151211+80c5cb6+20trusty-ubuntugis). Men:
>   Pakke qgis-providers-common er ikke satt opp enda.
> dpkg: error processing package qgis-providers (--configure):
>  kravproblem - setter ikke opp pakken
> dpkg: dependency problems prevent configuration of qgis:
>  qgis krever qgis-providers (=
>   Pakke qgis-providers er ikke satt opp enda.
> dpkg: error processing package qgis (--configure):
> dpkg: dependency problems prevent configuration of qgis-plugin-grass:
>  qgis-plugin-grass krever qgis (=
>   Pakke qgis er ikke satt opp enda.
> dpkg: error processing package qgis-plugin-grass (--configure):
>  kravproblem - setter ikke opp pakken (dependancy problem - cannotg
> Det oppsto feil ved behandling av:
>  qgis-providers
>  qgis
>  qgis-plugin-grass
> I can open QGIS, but I get two errors on startup and the python
> console,plugin installer, database manager are not available:
> An error occured during execution of following code:
> import pyplugin_installer
> traceback.print_exception() failed
> and
> pyplugin_installer.initPluginInstaller()
> Can anyone help?
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale     http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151215/4a250792/attachment.html>
