[Qgis-developer] Missing QGIS LTS nightly build
Jürgen E. Fischer jef at norbit.de
Mon Dec 21 01:05:18 PST 2015
Hi Ivan,
On Mon, 21. Dec 2015 at 08:42:12 +0100, Ivan Mincik wrote:
> I did expect that QGIS nightly build is triggered every day, when some new
> commit (change) exists in corresponding branch.
* Builds are triggered every day/night.
* The build is skipped if, there is still one running
* The build goes into the release repository instead of the nightly
  one, when there is a new release (as the nightly would be the same commit).
* 2.8.5 and 2.12.2 were on friday, so the build does both releases and
  master.
* 2.8.5 initially failed and needed 7895e99, 2.12.2 failed on trusty ubuntugis
  and will be added manually.
So it just needs a bit of patience.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151221/a1e06635/attachment.sig>
