[Qgis-developer] Missing QGIS LTS nightly build
Ivan Minčík
ivan.mincik at gmail.com
Mon Dec 21 01:44:04 PST 2015
On Dec 21, 2015 10:05 AM, "Jürgen E." <jef at norbit.de> wrote:
> Hi Ivan,
> On Mon, 21. Dec 2015 at 08:42:12 +0100, Ivan Mincik wrote:
> > I did expect that QGIS nightly build is triggered every day, when some
new
> > commit (change) exists in corresponding branch.
> * Builds are triggered every day/night.
> * The build is skipped if, there is still one running
> * The build goes into the release repository instead of the nightly
> one, when there is a new release (as the nightly would be the same
commit).
> * 2.8.5 and 2.12.2 were on friday, so the build does both releases and
> master.
I did expect that daily would be skipped if the release is the same commit,
but unfortunately I didn't found it.
> * 2.8.5 initially failed and needed 7895e99, 2.12.2 failed on trusty
ubuntugis
> and will be added manually.
> So it just needs a bit of patience.
Thank you very much for explanation and great work you are doing.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151221/757de871/attachment.html>
