[Qgis-developer] PyQgsDocCoverage failed, how to configure QGIS build ?
Nyall Dawson
nyall.dawson at gmail.com
Mon Dec 21 10:06:58 PST 2015
On 22 Dec 2015 04:35, "Matthias Kuhn" <matthias at opengis.ch> wrote:
> Hi René-Luc,
> It depends on which modules are built (and probably on other
> system-specific metrics). You can have a look into
> ci/travis/linux/install.sh
> With the same cmake options you should get at least close to what travis
> checks, but there may still be a delta.
> This test is not intended to pass locally and one should not care as
> long as it passes on travis.
Note that this is just a temporary situation. When the threshold hits 0,
the test will work consistently both locally and on Travis.
Nyall
> Bests,
> Matthias
> On 12/21/2015 04:34 PM, René-Luc Dhont wrote:
> > Hi devs,
> > Because PyQgsDocCoverage failed on travis for my PR #2549, I activated
> > it and tested it on my own computer.
> > On the master, I obtained 3857 instead of 3827 missing documentation.
> > I'd like to know ho to configured QGIS build to have this test passed ?
> > Regards,
> > René-Luc D'Hont
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151222/7659a91b/attachment-0001.html>
