[Qgis-developer] PyQgsDocCoverage failed, how to configure QGIS build ?
Matthias Kuhn
matthias at opengis.ch
Mon Dec 21 09:35:34 PST 2015
Hi René-Luc,
It depends on which modules are built (and probably on other
system-specific metrics). You can have a look into
ci/travis/linux/install.sh
With the same cmake options you should get at least close to what travis
checks, but there may still be a delta.
This test is not intended to pass locally and one should not care as
long as it passes on travis.
Bests,
Matthias
On 12/21/2015 04:34 PM, René-Luc Dhont wrote:
> Hi devs,
> Because PyQgsDocCoverage failed on travis for my PR #2549, I activated
> it and tested it on my own computer.
> On the master, I obtained 3857 instead of 3827 missing documentation.
> I'd like to know ho to configured QGIS build to have this test passed ?
> Regards,
> René-Luc D'Hont
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151221/62426650/attachment.sig>
