[Qgis-developer] QGIS server bad creashes
Andreas Neumann a.neumann at carto.net
Tue Dec 22 08:27:31 PST 2015
Hi Paolo,
I also have these crashes.
See http://hub.qgis.org/issues/13919
I am pretty sure it has to do with this "QGIS server security patch"
from Stéphane. My troubles started after this got merged into master.
Can you check if the version before
https://github.com/qgis/QGIS/commit/422abbde5e5b76924d3b78eba42d61a4f4c18563
is still ok?
  Andreas
On 22.12.2015 16:18, Paolo Cavallini wrote:
> Hi all,
> a new installation of qgis server is repeatedly crashing here[0]. The
> same projects are working with a previous installation. I also tried
> rebuilding a project from scratch, and it works with just one layer, as
> I add more I get the crash.
> Any hint? Seems a pretty serious issue.
> Thanks.
> [0]
> terminate called after throwing an instance of 'QgsCsException'
> [Tue Dec 22 16:14:38.084549 2015] [fcgid:warn] [pid 6313:tid
> 139918316934912] [client 127.0.0.1:54594] mod_fcgid: error reading data,
> FastCGI server closed connection
> [Tue Dec 22 16:14:38.084594 2015] [core:error] [pid 6313:tid
> 139918316934912] [client 127.0.0.1:54594] End of script output before
> headers: qgis_mapserv.fcgi
> 2015-12-22 16:14:38	79.1.153.81	warning	2015-12-22 16:14:38	[2]
> file_get_contents(http://127.0.0.1/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Flizmap_data%2Fgeosisma0.qgs&request=GetCapabilities&service=WMS&version=1.3.0):
> failed to open stream: HTTP request failed! HTTP/1.1 500 Internal Server
> Error
> 	/var/www/lizmap-web-client-2.12.2/lizmap/modules/lizmap/classes/lizmapCache.class.php	87
> [Tue Dec 22 16:14:43.280192 2015] [fcgid:error] [pid 6311:tid
> 139918472628096] mod_fcgid: process
> /usr/lib/cgi-bin/qgis_mapserv.fcgi(6378) exit(communication error), get
> unexpected signal 6
