[Qgis-developer] QGIS server bad creashes
René-Luc Dhont
rldhont at gmail.com
Tue Dec 22 08:29:20 PST 2015
Hi Andreas,
QGIS 2.8.5 does not integrate "QGIS server security patch". It cannont
be the cause of Paolo issue.
Regards,
Le 22/12/2015 17:27, Andreas Neumann a écrit :
> Hi Paolo,
> I also have these crashes.
> See http://hub.qgis.org/issues/13919
> I am pretty sure it has to do with this "QGIS server security patch"
> from Stéphane. My troubles started after this got merged into master.
> Can you check if the version before
> https://github.com/qgis/QGIS/commit/422abbde5e5b76924d3b78eba42d61a4f4c18563
> is still ok?
> Andreas
> On 22.12.2015 16:18, Paolo Cavallini wrote:
>> Hi all,
>> a new installation of qgis server is repeatedly crashing here[0]. The
>> same projects are working with a previous installation. I also tried
>> rebuilding a project from scratch, and it works with just one layer, as
>> I add more I get the crash.
>> Any hint? Seems a pretty serious issue.
>> Thanks.
>> [0]
>> terminate called after throwing an instance of 'QgsCsException'
>> [Tue Dec 22 16:14:38.084549 2015] [fcgid:warn] [pid 6313:tid
>> 139918316934912] [client 127.0.0.1:54594] mod_fcgid: error reading data,
>> FastCGI server closed connection
>> [Tue Dec 22 16:14:38.084594 2015] [core:error] [pid 6313:tid
>> 139918316934912] [client 127.0.0.1:54594] End of script output before
>> headers: qgis_mapserv.fcgi
>> 2015-12-22 16:14:38 79.1.153.81 warning 2015-12-22
>> 16:14:38 [2]
>> file_get_contents(http://127.0.0.1/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Flizmap_data%2Fgeosisma0.qgs&request=GetCapabilities&service=WMS&version=1.3.0):
>> failed to open stream: HTTP request failed! HTTP/1.1 500 Internal Server
>> Error
>> /var/www/lizmap-web-client-2.12.2/lizmap/modules/lizmap/classes/lizmapCache.class.php
>> 87
>> [Tue Dec 22 16:14:43.280192 2015] [fcgid:error] [pid 6311:tid
>> 139918472628096] mod_fcgid: process
>> /usr/lib/cgi-bin/qgis_mapserv.fcgi(6378) exit(communication error), get
>> unexpected signal 6
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
