[Qgis-developer] QGIS server bad creashes
Andreas Neumann
a.neumann at carto.net
Tue Dec 22 08:30:52 PST 2015
Yes, I know -
but with my projects it works fine before that commit and crashes
reliably after that crash.
The other thing is that it got horribly slow after that commit.
Maybe there are two different overlapping issues, though.
Andreas
On 22.12.2015 17:29, René-Luc Dhont wrote:
> Hi Andreas,
> QGIS 2.8.5 does not integrate "QGIS server security patch". It cannont
> be the cause of Paolo issue.
> Regards,
> Le 22/12/2015 17:27, Andreas Neumann a écrit :
>> Hi Paolo,
>> I also have these crashes.
>> See http://hub.qgis.org/issues/13919
>> I am pretty sure it has to do with this "QGIS server security patch"
>> from Stéphane. My troubles started after this got merged into master.
>> Can you check if the version before
>> https://github.com/qgis/QGIS/commit/422abbde5e5b76924d3b78eba42d61a4f4c18563
>> is still ok?
>> Andreas
>> On 22.12.2015 16:18, Paolo Cavallini wrote:
>>> Hi all,
>>> a new installation of qgis server is repeatedly crashing here[0]. The
>>> same projects are working with a previous installation. I also tried
>>> rebuilding a project from scratch, and it works with just one layer, as
>>> I add more I get the crash.
>>> Any hint? Seems a pretty serious issue.
>>> Thanks.
>>> [0]
>>> terminate called after throwing an instance of 'QgsCsException'
>>> [Tue Dec 22 16:14:38.084549 2015] [fcgid:warn] [pid 6313:tid
>>> 139918316934912] [client 127.0.0.1:54594] mod_fcgid: error reading
>>> data,
>>> FastCGI server closed connection
>>> [Tue Dec 22 16:14:38.084594 2015] [core:error] [pid 6313:tid
>>> 139918316934912] [client 127.0.0.1:54594] End of script output before
>>> headers: qgis_mapserv.fcgi
>>> 2015-12-22 16:14:38 79.1.153.81 warning 2015-12-22
>>> 16:14:38 [2]
>>> file_get_contents(http://127.0.0.1/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Flizmap_data%2Fgeosisma0.qgs&request=GetCapabilities&service=WMS&version=1.3.0):
>>> failed to open stream: HTTP request failed! HTTP/1.1 500 Internal
>>> Server
>>> Error
>>> /var/www/lizmap-web-client-2.12.2/lizmap/modules/lizmap/classes/lizmapCache.class.php
>>> 87
>>> [Tue Dec 22 16:14:43.280192 2015] [fcgid:error] [pid 6311:tid
>>> 139918472628096] mod_fcgid: process
>>> /usr/lib/cgi-bin/qgis_mapserv.fcgi(6378) exit(communication error), get
>>> unexpected signal 6
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
