[Qgis-developer] QGIS server bad creashes
    Stéphane Brunner
    stephane.brunner at camptocamp.com
    Tue Dec 22 08:33:41 PST 2015
Hello,
I know that's not ready, bet does this fix your issue?
https://github.com/qgis/QGIS/pull/2567
Sincerely
Stéphane
2015-12-22 17:30 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Yes, I know -
> but with my projects it works fine before that commit and crashes reliably
> after that crash.
> The other thing is that it got horribly slow after that commit.
> Maybe there are two different overlapping issues, though.
> Andreas
> On 22.12.2015 17:29, René-Luc Dhont wrote:
>> Hi Andreas,
>> QGIS 2.8.5 does not integrate "QGIS server security patch". It cannont be
>> the cause of Paolo issue.
>> Regards,
>> Le 22/12/2015 17:27, Andreas Neumann a écrit :
>>> Hi Paolo,
>>> I also have these crashes.
>>> See http://hub.qgis.org/issues/13919
>>> I am pretty sure it has to do with this "QGIS server security patch"
>>> from Stéphane. My troubles started after this got merged into master.
>>> Can you check if the version before
>>> https://github.com/qgis/QGIS/commit/422abbde5e5b76924d3b78eba42d61a4f4c18563
>>> is still ok?
>>>  Andreas
>>> On 22.12.2015 16:18, Paolo Cavallini wrote:
>>>> Hi all,
>>>> a new installation of qgis server is repeatedly crashing here[0]. The
>>>> same projects are working with a previous installation. I also tried
>>>> rebuilding a project from scratch, and it works with just one layer, as
>>>> I add more I get the crash.
>>>> Any hint? Seems a pretty serious issue.
>>>> Thanks.
>>>> [0]
>>>> terminate called after throwing an instance of 'QgsCsException'
>>>> [Tue Dec 22 16:14:38.084549 2015] [fcgid:warn] [pid 6313:tid
>>>> 139918316934912] [client 127.0.0.1:54594] mod_fcgid: error reading
>>>> data,
>>>> FastCGI server closed connection
>>>> [Tue Dec 22 16:14:38.084594 2015] [core:error] [pid 6313:tid
>>>> 139918316934912] [client 127.0.0.1:54594] End of script output before
>>>> headers: qgis_mapserv.fcgi
>>>> 2015-12-22 16:14:38    79.1.153.81    warning    2015-12-22 16:14:38
>>>> [2]
>>>> file_get_contents(
>>>> http://127.0.0.1/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Flizmap_data%2Fgeosisma0.qgs&request=GetCapabilities&service=WMS&version=1.3.0):
>>>> failed to open stream: HTTP request failed! HTTP/1.1 500 Internal Server
>>>> Error
>>>> /var/www/lizmap-web-client-2.12.2/lizmap/modules/lizmap/classes/lizmapCache.class.php
>>>> 87
>>>> [Tue Dec 22 16:14:43.280192 2015] [fcgid:error] [pid 6311:tid
>>>> 139918472628096] mod_fcgid: process
>>>> /usr/lib/cgi-bin/qgis_mapserv.fcgi(6378) exit(communication error), get
>>>> unexpected signal 6
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
camptocamp.com
mapfish.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151222/801636a7/attachment.html>
