[Qgis-developer] Feature fix #4273 and possibly #3756 (qgsdecorationitem)
Duncan
drrunnacles at googlemail.com
Wed Dec 30 02:50:41 PST 2015
Thanks for the info Nyall.
I'll get the pull request setup and see what comes back.
I've had a look at the test writing guidance on the site and have a rough idea of what to do, so I'll start getting them sorted while I wait for feedback on the pull request. If I get stuck I'll let you know.
Thanks again,
Duncan
On 30/12/15 10:01, Nyall Dawson wrote:
> On 30 Dec 2015 8:08 PM, "Duncan" <drrunnacles at googlemail.com> wrote:
>> Morning,
>> I've put the changes together for these features. This is my first contribution, so I wondered if I could check that I'm making the pull request properly. Hopefully make it a bit easier for whoever deals with it.
> Sounds great - and much appreciated! My advice would be to open the
> pull request whenever you're ready. Then we can look over whatever
> you've got already and make suggestions from there. Sometimes if
> you're unsure it's better to open a request early, just to get
> feedback on whether you're taking the right approach before sinking
> too much work into it.
> I'm sure you'll find the QGIS community welcoming to new contributions
> and always happy to help out new developers. I'm also willing to help
> mentor/guide new contributors through changes if they relate to an
> area of the code I'm confident in. Just ask if you get stuck.
>> I ran the changes through prepare-commit.sh which fixed a few formatting issues. I plan to rebase the
>> branch onto the latest main and push up to my forked github repo and issue the pull request.
>> I've made a couple of amendments to the dialogs for the north arrow, scalebar and copyright decoration items. Should I check these with anyone before making the pull request?
> No, just open when you're ready. The CI testing (Travis) will kick in
> and run over you're changes to verify that there's no regressions or
> code issues. With any luck you'll get a green light straight away, and
> if not someone will let you know what's gone wrong.
>> There aren't any existing tests for these classes. Would you like me to put some together for them?
> New tests are always very welcome! Again, ping if you need any
> guidance on our testing infrastructure.
> Nyall
