[Qgis-developer] What happened to processing.runalg?
Tim Sutton
tim at kartoza.com
Fri Feb 6 05:41:49 PST 2015
Hi All
Once of our tests in InaSAFE fails against master (see below). Can someone
tell me where runalg went, and more broadly which parts of the processing
framework can be relied of as API compatible between releases? I guess more
and more people will start relying on its API and we should make it clear
what the best practice is.
Thanks!
Regards
Tim
ERROR: Test if line aggregation works
File
"/home/timlinux/dev/python/inasafe-dev/safe/impact_statistics/test/test_aggregator.py",
line 596, in test_line_aggregation
impact_layer_attributes=impact_layer_attributes)
File
line 338, in _aggregate
aggregator.aggregate(impact_layer)
File
"/home/timlinux/dev/python/inasafe-dev/safe/impact_statistics/aggregator.py",
line 527, in aggregate
qgis_impact_layer, safe_impact_layer)
File
line 634, in _aggregrate_vector_impact
self._aggregate_line_impact(safe_impact_layer)
File
line 920, in _aggregate_line_impact
res = self.processing.runalg('qgis:intersection',
AttributeError: 'module' object has no attribute 'runalg'
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150206/550c5ab5/attachment.html>
