[Qgis-developer] What happened to processing.runalg?
Arnaud Morvan
arnaud.morvan at camptocamp.com
Fri Feb 6 05:52:11 PST 2015
I've just meet the same problem
it comes from this commit :
https://github.com/qgis/QGIS/commit/956c155e8f45cb1a0fc4c5d6204f607f80edc6b0#diff-111
some imports where removes from processing.__init__.py in context of a
pep8 check
this is the source of the regression
Arnaud
Le 06/02/2015 14:41, Tim Sutton a écrit :
> Hi All
> Once of our tests in InaSAFE fails against master (see below). Can
> someone tell me where runalg went, and more broadly which parts of the
> processing framework can be relied of as API compatible between
> releases? I guess more and more people will start relying on its API
> and we should make it clear what the best practice is.
> Thanks!
> Regards
> Tim
> ERROR: Test if line aggregation works
> Traceback (most recent call last):
> File
> "/home/timlinux/dev/python/inasafe-dev/safe/impact_statistics/test/test_aggregator.py",
> line 596, in test_line_aggregation
> impact_layer_attributes=impact_layer_attributes)
> File
> line 338, in _aggregate
> aggregator.aggregate(impact_layer)
> File
> "/home/timlinux/dev/python/inasafe-dev/safe/impact_statistics/aggregator.py",
> line 527, in aggregate
> qgis_impact_layer, safe_impact_layer)
> File
> line 634, in _aggregrate_vector_impact
> self._aggregate_line_impact(safe_impact_layer)
> File
> line 920, in _aggregate_line_impact
> res = self.processing.runalg('qgis:intersection',
> AttributeError: 'module' object has no attribute 'runalg'
> Tim Sutton
> Visit http://kartoza.com <http://kartoza.com/> to find out about open
> source:
> * Desktop GIS programming services
> * Geospatial web development
> * GIS Training
> * Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> <http://freenode.net/>
> Tim is a member of the QGIS Project Steering Committee
> Kartoza is a merger between Linfiniti and Afrispatial
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150206/f5088450/attachment-0001.html>
