[Qgis-developer] error in compiling (QWTPOLAR_INCLUDE_DIR)
Nyall Dawson
nyall.dawson at gmail.com
Sun Feb 8 01:42:53 PST 2015
On 8 Feb 2015 8:04 pm, "Matthias Kuhn" <matthias at opengis.ch> wrote:
> Hi Matteo,
> What is the status of
> WITH_QWTPOLAR
> and
> WITH_INTERNAL_QWTPOLAR
> on Ubuntu you will probably have to set them both to TRUE or set
WITH_QWTPOLAR to FALSE (in which case, if you still experience troubles you
may have to delete the variables QWTPOLAR_INCLUDE_DIR and QWTPOLAR_LIBRARY.
Deleting these is not the same as setting them to OFF.)
That should be fixed in master now - try an updated build.
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150208/beb9d814/attachment.html>
