[Qgis-developer] error in compiling (QWTPOLAR_INCLUDE_DIR)
Ivan Mincik
ivan.mincik at gmail.com
Tue Feb 24 11:15:44 PST 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 08.02.2015 10:42, Nyall Dawson wrote:
> On 8 Feb 2015 8:04 pm, "Matthias Kuhn" <matthias at opengis.ch>
> wrote:
>> Hi Matteo,
>> What is the status of WITH_QWTPOLAR and WITH_INTERNAL_QWTPOLAR
>> on Ubuntu you will probably have to set them both to TRUE or set
> WITH_QWTPOLAR to FALSE (in which case, if you still experience
> troubles you may have to delete the variables QWTPOLAR_INCLUDE_DIR
> and QWTPOLAR_LIBRARY. Deleting these is not the same as setting
> them to OFF.)
> That should be fixed in master now - try an updated build.
> Nyall
Nyall, could be this fix backported to release_2_8 branch ?
Ivan Min?ík
ivan.mincik at gmail.com GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJU7M3cAAoJEPfdLsR5UpoeBnQH/R7gQtUuKgc6kVSODvsf1VjK
HLn3yw/FwyTAgZEz1c4OLEhM4AbvarxKOcDBuqlcls/Z2gOuRp4FE7urll+Vjqwm
SJSunfK3NzWf142RZgtW1CS9KqQmuIkK+pqEHeFICmX7CcM2zjZ2JMu65dF380CF
jsOBFGGa6ZqvEiBqlSZbKQecLhDN29J+vfF16VbEX2GHnHiowJb+mR0pRruplh4w
CSf+B1EPvUw7iv2IqyJFWQFh8qahA5muFRjSKNk183i1gnEslEfLBN/YSDbhzY6d
NZImXetc2Ze78xP2gFMnHcn+rrY1pcmsgwP4+0UI5rEG2LNVVU9kD1WlTOHG7v8=
=9jef
-----END PGP SIGNATURE-----
