Not sure if anyone else has noticed this. QGIS 2.6.x on Ubuntu 14.04 If you click the Browser tab as your 1st click inside a fresh run of QGIS it crashes. Click anything else and then Browser and it's fine. I've gotten it to work on several machines. I'm not sure it's in master, but someone should probably check. Thanks, Alex
