[Qgis-developer] Compression in libpq?
Jean-Roc Morreale jr.morreale at enoreth.net
Fri Feb 13 01:31:27 PST 2015
Andreas, did you you try to setup these connection over ssh ? ssh -C
uses gzip
Le 2015-02-13 10:26, Andreas Neumann a écrit :
> Hi,
> Just came across this:
> http://michael.otacoo.com/postgresql-2/postgres-9-5-feature-highlight-pglz-compression-libpqcommon/
> This read is very technical.
> Question: does this mean that a future libpq will support compression?
> I think this would be very interesting for us, esp. if you work with
> PostgreSQL connections through slower network connections. I always
> found remote Postgis connections that are not on the same LAN quite
> slow.
> Any comments?
> Andreas
> Qgis-developer mailing list
