[Qgis-developer] Compression in libpq?
Andreas Neumann
a.neumann at carto.net
Fri Feb 13 01:35:36 PST 2015
Hi Jean-Roc,
Thanks about this hint. I am vaguely aware about this option with pg
connections through ssh with gzip. But I did not try it. Do you have any
pointers how to set this up?
Anyway - having this built in to our existing software without having to
set up ssh connections would be a big plus.
Thanks,
Andreas
On 13.02.2015 10:31, Jean-Roc Morreale wrote:
> Andreas, did you you try to setup these connection over ssh ? ssh -C
> uses gzip
> Le 2015-02-13 10:26, Andreas Neumann a écrit :
>> Hi,
>> Just came across this:
>> http://michael.otacoo.com/postgresql-2/postgres-9-5-feature-highlight-pglz-compression-libpqcommon/
>> This read is very technical.
>> Question: does this mean that a future libpq will support compression?
>> I think this would be very interesting for us, esp. if you work with
>> PostgreSQL connections through slower network connections. I always
>> found remote Postgis connections that are not on the same LAN quite
>> slow.
>> Any comments?
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
