[Qgis-developer] QGIS Server and QGIS_OPTION(S)_PATH
Andreas Neumann
a.neumann at carto.net
Mon Feb 16 00:54:56 PST 2015
I am trying to get correct NULL values in the GetFeatureInfo response of
QGIS server.
Just recently this was fixed by Jürgen - see
http://hub.qgis.org/issues/12114
So I recompiled and tried to configure the NULL setting in a QGIS.ini
file. However, I seem to have troubles with my configuration. Strings
still appear as "" instead of NULL and missing values for numbers as 0.
Here is what I tried:
specified variable QGIS_OPTIONS_PATH in
/etc/apache2/mods-enabled/env.conf:
SetEnv QGIS_OPTIONS_PATH "/etc"
I placed a file at /etc/QGIS/QGIS.ini (also tried QGIS2.ini) - neither
worked.
Content of the file:
[Qgis]
nullValue=NULL
Do you have any idea what I did wrong that NULL values still don't work
in QGIS Server GetFeatureInfo?
Thanks,
Andreas
