[Qgis-developer] QGIS Server and QGIS_OPTION(S)_PATH
Jürgen E. Fischer jef at norbit.de
Mon Feb 16 01:22:59 PST 2015
Hi Andreas,
On Mon, 16. Feb 2015 at 09:54:56 +0100, Andreas Neumann wrote:
> specified variable QGIS_OPTIONS_PATH in
> /etc/apache2/mods-enabled/env.conf:
> SetEnv QGIS_OPTIONS_PATH "/etc"
> I placed a file at /etc/QGIS/QGIS.ini (also tried QGIS2.ini) -
> neither worked.
The ini file should be in the path that QGIS_OPTIONS_PATH points to.
> Content of the file:
> [Qgis]
> nullValue=NULL
That's the default anyway.  So it doesn't matter whether or not the file is
found.   Which format are you requesting GetFeatureInfo in?  Did you try with
QGIS Desktop?  Because that's what I did.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150216/8c8f0378/attachment.pgp>
