[Qgis-developer] QGIS Server and QGIS_OPTION(S)_PATH
Andreas Neumann
a.neumann at carto.net
Mon Feb 16 01:41:23 PST 2015
Hi Jürgen,
I am sorry - my fault. I compiled and then forgot "make install" - so it
was still using the old version. NULL values are working fine now -
thanks!
I have three more questions regarding the ini file:
1.
should it be QGIS_OPTIONS_PATH or QGIS_OPTION_PATH? I see both
variations out there.
2.
So if, my ini-file is in /etc/QGIS/QGIS.ini I need to point
QGIS_OPTIONS_PATH to
/etc/QGIS ?
3.
should it be QGIS.ini or QGIS2.ini ?
I found documentation at
http://docs.qgis.org/2.6/uk/docs/user_manual/working_with_ogc/ogc_server_support.html#environment-variables
QGIS_OPTIONS_PATH: The variable specifies path to directory with
settings. It works the same ways as QGIS application –optionspath
option. It is looking for settings file in
<QGIS_OPTIONS_PATH>/QGIS/QGIS2.ini. For exaple, to set QGIS server on
Apache to use /path/to/config/QGIS/QGIS2.ini settings file, add to
Apache config:
SetEnv QGIS_OPTIONS_PATH "/path/to/config/"
Is this information wrong then?
Thanks,
Andreas
Am 2015-02-16 10:22, schrieb Jürgen E. Fischer:
> Hi Andreas,
> On Mon, 16. Feb 2015 at 09:54:56 +0100, Andreas Neumann wrote:
>> specified variable QGIS_OPTIONS_PATH in
>> /etc/apache2/mods-enabled/env.conf:
>> SetEnv QGIS_OPTIONS_PATH "/etc"
>> I placed a file at /etc/QGIS/QGIS.ini (also tried QGIS2.ini) -
>> neither worked.
> The ini file should be in the path that QGIS_OPTIONS_PATH points to.
>> Content of the file:
>> [Qgis]
>> nullValue=NULL
> That's the default anyway. So it doesn't matter whether or not the
> file is
> found. Which format are you requesting GetFeatureInfo in? Did you
> try with
> QGIS Desktop? Because that's what I did.
> Jürgen
> Qgis-developer mailing list
