[Qgis-developer] Better tags for plugins
Alessandro Pasotti
apasotti at gmail.com
Thu Feb 19 23:13:32 PST 2015
2015-02-20 1:47 GMT+01:00 Trevor Wiens <tsw.web at gmail.com>:
> I took a look through the list and if you wany to make a consistent set of
> tags to use then the list will need to be short and obvious.In this light I
> would make the following suggestions:
> 1. The is comprised of items that could be used to make components of larger
> items. If there is a desire to make the list standard but not be a
> prescriptive as categories individual tags could be used to describe more
> complex tasks. For example right now there is:
> attribute
> attribute edit
> attribute table
> These could be replaced by attribute, edit, and table and combined with
> other things to keep the list short
> 2. There isn't a consistent time tense in the terms, for example geocoding
> and print. Using geocode and print would be more consistent
> 3. bing and google are listed, perhaps a use of wms would be sufficient
> 4.Some items are plural and other singular. Again it would be more
> consistent for all tags to be singular if possible
> There may be other was the list can be shortened even further but those are
> my thoughts for now.
> TSW
Thanks for the suggestions, most of us are not mothertongue english
speakers and your help is precious.
Would you mind writing a short sentence that summarize the rules for
an ideal tag?
I could add them into http://plugins.qgis.org website and maybe they
can also be added to the plugin builder.
For Bing and Google, technically speaking they aren't WMS, more like TMS.
Alessandro Pasotti
w3: www.itopen.it
