[Qgis-developer] Print composer font pickers are broken
Nyall Dawson nyall.dawson at gmail.com
Mon Feb 23 00:15:15 PST 2015
On 23 February 2015 at 19:09, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 22-02-15 22:33, Nyall Dawson wrote:
>> ... however... making this change meant we got hit with a Qt bug [1]
>> which causes font dialogs with a parent window set to effectively
>> discard their results. Arghh! The worst part is that Jürgen had
>> actually fixed this issue 3 years ago - I should have checked the git
>> history on the effected files to see if there was an explicit reason
>> the parent wasn't correctly set for these dialogs.
> Checking git is one thing (I'm not blaming you for not doing this for
> every change...), but maybe also add a comment about this above the line
> of code, as more and more people are hacking or trying to clean up in
> QGIS, and this knowledge should be IN the code instead of heads and githubs?
Already done (by Jürgen):
https://github.com/qgis/QGIS/commit/57ba28c344ed03cd555c31b0301311a93f988e83
Nyall
