[Qgis-developer] Globe plugin with osgEarth 2.6
Matthias Kuhn matthias at opengis.ch
Thu Feb 26 22:27:42 PST 2015
I have spent some time on the globe plugin about a year ago. I managed
to compile against osgEarth 2.5 at that time and even could use some of
the features (vertical exaggeration to name an interesting one). I never
got around to merge this back.
You may give this branch a try.
https://github.com/m-kuhn/QGIS/commits/globe-featurequery
Cheers
Matthias
On 02/26/2015 11:25 PM, samuelmesa at gmail.com wrote:
> Hi list. I tried to compile QGIS with the latest osgEarth 2.6[1],
> however, the following error is reported[2]:
> [ 92%] Building CXX object
> src/plugins/globe/CMakeFiles/globeplugin.dir/globe_plugin.cpp.o
> /home/samtux/Manjaro/aur/qgis/src/qgis/src/plugins/globe/globe_plugin.cpp:60:32:
> error fatal: osgEarthUtil/SkyNode: No existe el fichero o el directorio
>  #include <osgEarthUtil/SkyNode>
> compilación terminada.
> src/plugins/globe/CMakeFiles/globeplugin.dir/build.make:78: fallo en
> las instrucciones para el objetivo
> 'src/plugins/globe/CMakeFiles/globeplugin.dir/globe_plugin.cpp.o'
> make[2]: ***
> [src/plugins/globe/CMakeFiles/globeplugin.dir/globe_plugin.cpp.o] Error 1
> CMakeFiles/Makefile2:2567: fallo en las instrucciones para el objetivo
> 'src/plugins/globe/CMakeFiles/globeplugin.dir/all'
> make[1]: *** [src/plugins/globe/CMakeFiles/globeplugin.dir/all] Error 2
> Makefile:137: fallo en las instrucciones para el objetivo 'all'
> make: *** [all] Error 2
> Is it possible to build QGIS with the latest OSGEarth?.
> [1]  http://osgearth.org/
> [2]
> http://forum.osgearth.org/Missing-include-OSGearth-2-6-for-QGIS-Globe-td7586783.html
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150227/c556bba4/attachment.html>
