[Qgis-developer] Possible regression with QGIS v2.8.1 with rasters rotated/skew via worldfile
Even Rouault
even.rouault at spatialys.com
Fri Feb 27 11:32:47 PST 2015
Le vendredi 27 février 2015 20:23:49, Jesse McGraw a écrit :
> I'm seeing a potential regression with QGIS v2.8.1 on under Xubuntu v14.10
> I'm loading some .PNGs that have .wld files associated with them. Ones
> that have rotation/skew values other than 0 are no longer displaying where
> they had been working fine under v2.6.1. Rasters that have 0 rotation/skew
> values show up fine and are georeferenced properly
You likely hit http://hub.qgis.org/issues/12264 /
https://github.com/qgis/QGIS/commit/f106a2ef999224f1f1b7f214d08b039749d6111b
Has been fixed in master, but not backported yet in 2.8 branch AFAICS
Possible workaround if you're stuck. Use output of "gdalwarp your.png out.tif"
or "gdalwarp your.png out.vrt -of VRT"
> I tried toggling off the experimental canvas rotation option but that
> didn't help
> I can send the raster and world files if it will help any troubleshooting.
> Thanks,
> Jesse
> About QGIS:
> QGIS version 2.8.1-Wien QGIS code revision exported
> Compiled against Qt 4.8.6 Running against Qt 4.8.6
> Compiled against GDAL/OGR 1.10.1 Running against GDAL/OGR 1.10.1
> Compiled against GEOS 3.4.2-CAPI-1.8.2 Running against GEOS
> 3.4.2-CAPI-1.8.2 r3921
> PostgreSQL Client Version 9.4beta3 SpatiaLite Version 4.1.1
> QWT Version 5.2.3 PROJ.4 Version 480
> QScintilla2 Version 2.8.3
http://www.spatialys.com
