[Qgis-developer] Possible regression with QGIS v2.8.1 with rasters rotated/skew via worldfile
Jesse McGraw
jlmcgraw at gmail.com
Fri Feb 27 11:41:42 PST 2015
Thanks Even. Do you ever sleep? :)
On Fri, Feb 27, 2015 at 2:32 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le vendredi 27 février 2015 20:23:49, Jesse McGraw a écrit :
> > I'm seeing a potential regression with QGIS v2.8.1 on under Xubuntu
> v14.10
> > I'm loading some .PNGs that have .wld files associated with them. Ones
> > that have rotation/skew values other than 0 are no longer displaying
> where
> > they had been working fine under v2.6.1. Rasters that have 0
> rotation/skew
> > values show up fine and are georeferenced properly
> You likely hit http://hub.qgis.org/issues/12264 /
> https://github.com/qgis/QGIS/commit/f106a2ef999224f1f1b7f214d08b039749d6111b
> Has been fixed in master, but not backported yet in 2.8 branch AFAICS
> out.tif"
> or "gdalwarp your.png out.vrt -of VRT"
> > I tried toggling off the experimental canvas rotation option but that
> > didn't help
> > I can send the raster and world files if it will help any
> troubleshooting.
> > Thanks,
> > Jesse
> > About QGIS:
> > QGIS version 2.8.1-Wien QGIS code revision exported
> > Compiled against Qt 4.8.6 Running against Qt 4.8.6
> > Compiled against GDAL/OGR 1.10.1 Running against GDAL/OGR 1.10.1
> > Compiled against GEOS 3.4.2-CAPI-1.8.2 Running against GEOS
> > 3.4.2-CAPI-1.8.2 r3921
> > PostgreSQL Client Version 9.4beta3 SpatiaLite Version 4.1.1
> > QWT Version 5.2.3 PROJ.4 Version 480
> > QScintilla2 Version 2.8.3
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150227/3d80c726/attachment-0001.html>
