[Qgis-developer] info about plugin and processing toolbox
Victor Olaya volayaf at gmail.com
Sat Feb 28 10:09:42 PST 2015
you can add a combo box in a script, using "selection" as data type,
followed by the possible values separated by semicolons
For instance
method=selection First method;Another method;The last method
Hope this helps
2015-02-28 18:34 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Sergio,
> look at the Example Provider code [0]. This is example developed specially
> as tutorial how to implement own provider plugins for Processing.
> [0] https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/exampleprovider
> 2015-02-28 19:21 GMT+02:00 Sergio Vignali <vignalisergio30 at gmail.com>:
>> Thank you Victor and Anita,
>> maybe my message was not so clear. Yes I know how to write a simple script,
>> but I would like to transform it in a plugin.
>> The simple script, for that I know, does not allow to insert a combobox
>> while in some plugin like LECOS there is one.
>> It is difficult for me reading the plugin code and understand which part is
>> for a normal plugin and which one for the processing toolbox, if you have
>> any suggestion please let me know.
>> Best
>> Sergio
>> 2015-02-28 18:05 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
>>> On Sat, Feb 28, 2015 at 5:47 PM, Sergio Vignali
>>> <vignalisergio30 at gmail.com> wrote:
>>>> Dear all,
>>>> I would like to know if there is a tutorial or text that explains how to
>>>> write a plugin for the processing toolbox. The QGis documentation explains
>>>> how to write a plugin but I didn't find anything about the processing
>>>> toolbox... So I would like to know the structure and the code necessary to
>>>> add some script to the toolbox.
>>> Hi Sergio,
>>> If you just want to add a simple script to the Processing toolbox, you
>>> don't need a plugin at all. All you need to do is go to Scripts | Tools |
>>> Create new script in the toolbox. You can find many examples of how these
>>> scripts have to look like in the following repository:
>>> https://github.com/qgis/QGIS-Processing/tree/master/scripts
>>> Best wishes
>>> Anita
>> Sergio Vignali
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
