[Qgis-developer] info about plugin and processing toolbox
Sergio Vignali vignalisergio30 at gmail.com
Sat Feb 28 10:25:07 PST 2015
I didn't know the selection data type, this is cool, thanks Victor!
and thanks Alexander, the example provider is really useful
All the best
s.
2015-02-28 19:09 GMT+01:00 Victor Olaya <volayaf at gmail.com>:
> you can add a combo box in a script, using "selection" as data type,
> followed by the possible values separated by semicolons
> For instance
> method=selection First method;Another method;The last method
> Hope this helps
> 2015-02-28 18:34 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
> > Hi Sergio,
> > look at the Example Provider code [0]. This is example developed
> specially
> > as tutorial how to implement own provider plugins for Processing.
> > [0]
> https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/exampleprovider
> > 2015-02-28 19:21 GMT+02:00 Sergio Vignali <vignalisergio30 at gmail.com>:
> >> Thank you Victor and Anita,
> >> maybe my message was not so clear. Yes I know how to write a simple
> script,
> >> but I would like to transform it in a plugin.
> >> The simple script, for that I know, does not allow to insert a combobox
> >> while in some plugin like LECOS there is one.
> >> It is difficult for me reading the plugin code and understand which
> part is
> >> for a normal plugin and which one for the processing toolbox, if you
> have
> >> any suggestion please let me know.
> >> Best
> >> Sergio
> >> 2015-02-28 18:05 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
> >>> On Sat, Feb 28, 2015 at 5:47 PM, Sergio Vignali
> >>> <vignalisergio30 at gmail.com> wrote:
> >>>> Dear all,
> >>>> I would like to know if there is a tutorial or text that explains how
> to
> >>>> write a plugin for the processing toolbox. The QGis documentation
> explains
> >>>> how to write a plugin but I didn't find anything about the processing
> >>>> toolbox... So I would like to know the structure and the code
> necessary to
> >>>> add some script to the toolbox.
> >>> Hi Sergio,
> >>> If you just want to add a simple script to the Processing toolbox, you
> >>> don't need a plugin at all. All you need to do is go to Scripts |
> Tools |
> >>> Create new script in the toolbox. You can find many examples of how
> these
> >>> scripts have to look like in the following repository:
> >>> https://github.com/qgis/QGIS-Processing/tree/master/scripts
> >>> Best wishes
> >>> Anita
> >> Sergio Vignali
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Alexander Bruy
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150228/01e7b897/attachment.html>
