[Qgis-developer] info about plugin and processing toolbox
Sergio Vignali vignalisergio30 at gmail.com
Sat Feb 28 10:27:00 PST 2015
... and is also possible to include a check box in the script?
best
2015-02-28 19:25 GMT+01:00 Sergio Vignali <vignalisergio30 at gmail.com>:
> I didn't know the selection data type, this is cool, thanks Victor!
> and thanks Alexander, the example provider is really useful
> All the best
> s.
> 2015-02-28 19:09 GMT+01:00 Victor Olaya <volayaf at gmail.com>:
>> you can add a combo box in a script, using "selection" as data type,
>> followed by the possible values separated by semicolons
>> For instance
>> method=selection First method;Another method;The last method
>> Hope this helps
>> 2015-02-28 18:34 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
>> > Hi Sergio,
>> > look at the Example Provider code [0]. This is example developed
>> specially
>> > as tutorial how to implement own provider plugins for Processing.
>> > [0]
>> https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/exampleprovider
>> > 2015-02-28 19:21 GMT+02:00 Sergio Vignali <vignalisergio30 at gmail.com>:
>> >> Thank you Victor and Anita,
>> >> maybe my message was not so clear. Yes I know how to write a simple
>> script,
>> >> but I would like to transform it in a plugin.
>> >> The simple script, for that I know, does not allow to insert a combobox
>> >> while in some plugin like LECOS there is one.
>> >> It is difficult for me reading the plugin code and understand which
>> part is
>> >> for a normal plugin and which one for the processing toolbox, if you
>> have
>> >> any suggestion please let me know.
>> >> Best
>> >> Sergio
>> >> 2015-02-28 18:05 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
>> >>> On Sat, Feb 28, 2015 at 5:47 PM, Sergio Vignali
>> >>> <vignalisergio30 at gmail.com> wrote:
>> >>>> Dear all,
>> >>>> I would like to know if there is a tutorial or text that explains
>> how to
>> >>>> write a plugin for the processing toolbox. The QGis documentation
>> explains
>> >>>> how to write a plugin but I didn't find anything about the processing
>> >>>> toolbox... So I would like to know the structure and the code
>> necessary to
>> >>>> add some script to the toolbox.
>> >>> Hi Sergio,
>> >>> If you just want to add a simple script to the Processing toolbox, you
>> >>> don't need a plugin at all. All you need to do is go to Scripts |
>> Tools |
>> >>> Create new script in the toolbox. You can find many examples of how
>> these
>> >>> scripts have to look like in the following repository:
>> >>> https://github.com/qgis/QGIS-Processing/tree/master/scripts
>> >>> Best wishes
>> >>> Anita
>> >> Sergio Vignali
>> >> _______________________________________________
>> >> Qgis-developer mailing list
>> >> Qgis-developer at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Alexander Bruy
> Sergio Vignali
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150228/c948762e/attachment-0001.html>
