[Qgis-developer] processing - new geoalgorithme FieldsMapper
Arnaud Morvan
arnaud.morvan at camptocamp.com
Fri Jan 9 04:26:05 PST 2015
I've made a Pull Request in processing plugin with a new GeoAlgorithm.
https://github.com/qgis/QGIS/pull/1753
Can someone take a look at this (volaya or alexbruy), we would like it
to be pulled before feature freeze.
Objective of this new QGIS GeoAlgorithm is to provide a user friendly
tool to refactor layer fields.
It takes a standard ParameterVector as input.
From there, the user can :
* Change some field's names or type.
* Add or delete some fields.
* Reorder fields.
* Calculate new fields based on expressions.
The result is write through a standard OutputVector parameter.
This GeoAlgorithm can be used in modeler.
Arnaud
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150109/f43d29c9/attachment.html>
