[Qgis-developer] Multiple styles per layer
Martin Dobias
wonder.sk at gmail.com
Sun Jan 11 06:49:37 PST 2015
On Sun, Jan 11, 2015 at 5:01 AM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> In terms of UX, one thing I found strange is the fact that saving presets
> and saving styles work differently. Any change to the layer properties
> updates the current style, while any change in layers order, visibility or
> even choosen style is not saved to the "current" preset. You need to add a
> new preset to save that changes.
> So, if you want to create a new style you need to add one before you do
> any changes to properties, where in the presets you need to do the changes
> before you add a new preset (and it's not possible to update it)
I am aware of that - the visibility presets work as "snapshots" instead of
staying active when configuration changes. The reason behind this was that
due to implementation details it wasn't possible to have different active
sets of "checked legend items" - e.g. one set for main canvas and another
set for composer map. Now with changes I have done to support styles it
seems like there could be a way to make presets work like styles (to keep
the active configuration). Most likely I will not have a chance to work on
it before 2.8 feature freeze - but maybe in a future release...
Cheers
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150111/ce02706b/attachment.html>
